Stainless-steel pressure transducer
The PXM309 Metric Series transducer has a 0.25% static accuracy and a 1% total error band (TEB) over –20 to 85°C (on ranges of 1 to 700 bar). Ranges from 70 mbar to 3.5 bar are available with a slightly larger TEB
Aug. 25, 2011
The PXM309 Metric Series transducer has a 0.25% static accuracy and a 1% total error band (TEB) over –20 to 85°C (on ranges of 1 to 700 bar). Ranges from 70 mbar to 3.5 bar are available with a slightly larger TEB. The transducers are sealed to an IP65 environmental rating and are available with three electrical terminations, a 2-m cable with flying leads, a mini-DIN connector, or a fourpin M12 connector. The units are available with either 0 to 10-Vdc or 4 to 20-mA output.
Omega Engineering Inc.
One Omega Dr.
Stamford, CT 06907
(800) 826-6342
www. omega.com
© 2011 Penton Media, Inc.
