Fixed-field sensors with background suppression
Aug. 25, 2011
World-Beam Q20FF sensors deliver enhanced sensing capabilities with visible red, fixedfield- background suppression and a sensing range up to 6 in. (150 mm)
World-Beam Q20FF sensors deliver enhanced sensing capabilities with visible red, fixedfield- background suppression and a sensing range up to 6 in. (150 mm).
The Q20FF line provides optical performance in a worldwide standard rectangular sensor housing with 25.4-mm (1-in.) mounting hole spacing. Models are available with 2, 4, or 6-in. sensing ranges.
Additional key features include IP67/NEMA-6 and NEMA-PW12 1,200-psi wash-down rated; metallic M8 and M12 connectors on models with a threaded connection to the cordset; dc operation from 10 to 30 Vdc with complementary solid-state outputs (1 normally open, 1 normally closed); pnp (sourcing) or npn (sinking) by model; and mounting brackets and apertures.
Banner Engineering Corp.
9714 Tenth Ave. N
Minneapolis, MN 55441
(888) 373-6767
www.bannerengineering.com
© 2011 Penton Media, Inc.
