Linear actuator
Aug. 11, 2011
The Slick Stick screw-driven linear actuator is designed for applications with tight space restrictions. It has travel lengths up to 76 in. and speeds up to 20 ips
The Slick Stick screw-driven linear actuator is designed for applications with tight space restrictions. It has travel lengths up to 76 in. and speeds up to 20 ips. The actuator uses 1-in.-diameter aluminum tubing for stiffness and rigidity, and fits within an envelope equivalent to the size of a support-rail assembly. The drive screw is encased within the aluminum tubing for efficient use of space. The Slick Stick is available in single and multiaxis configurations.
Additional features include standard screw leads of 1 and 0.500 in., and horizontal, vertical, or lateral mounting.
Specialty Motion Inc.
1801 Railroad St.
Corona, CA 92880
(800) 283- 3411
www.smi4motion.com
© 2011 Penton Media, Inc.
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
