PTC Series push-to-connect fittings provide quick and simple tubing connection/ disconnection and leak-tight performance.
All fitting components are stainless steel, including the release collar, making them suitable for use in corrosive environments and in applications requiring “clean” materials. The fittings use captured O-ring face seals to ensure leak-tight operation. Buna-N O-ring seals are standard and fluorocarbon, silicone, and EPDM are also available.
Configurations include 10-32 threaded straight, adjustable position elbow, and adjustable position tee as well as “tube-to-tube” straight union, elbow, and tee models for ¼ and 1 /8 -in-OD tubing.
The fittings can be used with tubing materials such a polyurethane, polyethylene, and copper. For applications requiring corrosion resistance and/or elevated temperatures, the ¼-in.-OD size work with stainless-steel tubing
Beswick Engineering Co. Inc.
284 Ocean Rd.
Greenland, NH 03840
(603) 433-1188,
www.beswick.com
