Hall-effect joystick controller
June 9, 2011
The XL-VNSO is a one, two, and three-axis Halleffect joystick controller for high-duty cycle applications and rough environments that will provide precise proportional control of electrohydraulic proportional valve
The XL-VNSO is a one, two, and three-axis Halleffect joystick controller for high-duty cycle applications and rough environments that will provide precise proportional control of electrohydraulic proportional valves. The joystick accommodates applications that require digital or analog command signals to control variable-speed drives, PLCs, and microprocessors, including CANbus.
The controller is made with nickelchromium gimbal yokes, hardened steel bearings, polished-steel shaft guides, bronze gate-handle stops, and dual compression return springs in each axis. A variety of standard and custom gates and a large selection of handles are available.
J.R. Merritt Controls Inc.
55 Sperry Ave.
Stratford, CT 06615
(800) 333- 5762
www.jrmerritt.com
© 2011 Penton Media, Inc.
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
