Metcar 100 and 300 Series self-aligning bearing assemblies with carbon-graphite replaceable bearing cartridges, hold powered rollers in large continuous dryers used for curing gypsum board and ceiling tile.
The assemblies let users replace bearing cartridges quickly and easily even after years of exposure to the high temperatures. The 100 Series assemblies are for fast bearing-cartridge replacement from the axial direction, and the 300 Series replaces from the radial direction.
Several options are available for mounting to the dryer-support frame, including saddle, offset, vertical, horizontal, angle, flush, wing, and flange mounts.
Metallized Carbon Corp.
19 S. Water St.
Ossining, NY 10562
(914) 941-3738
www.metcar.com
