Food-grade bushing bearings
June 9, 2011
The food grade FluoroNyliner bushing bearings have a nonmagnetic 303 stainlesssteel corrosion-resistant sleeve with a selflubricating liner that is FDA and USDA compliant
The food grade FluoroNyliner bushing bearings have a nonmagnetic 303 stainlesssteel corrosion-resistant sleeve with a selflubricating liner that is FDA and USDA compliant. Available in open and closed types, the bearing-liner material can withstand a maximum continuous PV value of 10,000-psi fpm, handle a maximum static pressure of 1,000 psi, and provide maximum no-load speeds to 400 fpm in temperatures from –400 to 385°F.
The bushing bearings are available in optional stainless-steel pillow-block assembles in closed, open, flanged, and twin styles, and can be combined with a wide range of corrosion-resistant shafting options.
Thomson Industries Inc.
1500 Mittel Blvd.
Wood Dale, IL 60191
(630) 694- 3334
www.thomsonlinear.com
© 2011 Penton Media, Inc.
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
