Membrane-keypad access controller
June 9, 2011
The Membrane Keypad Access Controller provides keypad access for enclosures with up to 120 user codes, eliminating the need for mechanical keys
The Membrane Keypad Access Controller provides keypad access for enclosures with up to 120 user codes, eliminating the need for mechanical keys.
The keypad adheres to any door or frame and the remote controller mounts anywhere on or inside a cabinet. The keypad requires simple installation and programming, integrates directly with electronic locks, and offers programmable output timing. Dual outputs can also be independently controlled for applications requiring separate access privileges for multiple compartments.
Southco
Box 116
Concordville, PA 19331
(610) 459-4000
www.southco.com
© 2011 Penton Media, Inc.
