Worm-gear screw jacks
May 4, 2011
The ActionJac line of worm-gear screw jacks consists of machinescrew, ball-screw, stainless-steel, metric, and trapezoidal screw jack options. Used individually or in multiple arrangements
The ActionJac line of worm-gear screw jacks consists of machinescrew, ball-screw, stainless-steel, metric, and trapezoidal screw jack options. Used individually or in multiple arrangements, each jack is built to specification with customized travel lengths and load-handling capacities ranging from ¼ to 100 tons.
Each model’s worm-gear-set arrangement uses an alloy-steel worm, which drives a high-strength bronze worm gear (drive sleeve). The worm shaft is supported on antifriction tapered roller bearings with external seals to prevent loss of lubrication. Machine-screw jacks feature a lifting shaft made of alloy steel with a minimum tensile strength of 95,000 psi. Lead accuracy is approximately 0.004 in./ft.
Ball-screw jacks feature a high-efficiency ball screw and nut that reduces the required input torque to about one-third the torque required for machine-screw jacks. 300 Series Stainless-steel screw jack are for environments where corrosion resistance is essential. Stainless-steel lifting threads are precision formed to Class 2-C (centralizing) thread profiles.
Nook Industries Inc.
4950 EAST 49th St.
Cleveland, OH 44125
(800) 321-7800
www.nookindustries.com
© 2011 Penton Media, Inc.
June 27, 2025
June 25, 2025
June 25, 2025
