Hydraulic caliper-disc brake
April 19, 2011
The Model HOB-CP hydraulic caliper disc brakes operate when hydraulic pressure is applied. Available in three sizes (Model HOB-360CP, HOB-1200CP, and HOB-2800CP)
The Model HOB-CP hydraulic caliper disc brakes operate when hydraulic pressure is applied. Available in three sizes (Model HOB-360CP, HOB-1200CP, and HOB-2800CP), the brakes have maximum clamping forces of 810, 2,700, and 6,300 lb, respectively. Designed for heavy-duty work, the brakes modular design makes them easy to assemble and replace, reducing machine downtime.
Ogura Industrial Corp., Box 5790, Somerset, NJ 08875, (732) 271-7361, www.ogura-clutch.com
© 2011 Penton Media, Inc.
