EP35LV is a two component, room-temperature-curing, high-temperature-resistant epoxy adhesive. The epoxy produces high-strength bonds that are maintained even after long exposures to 450 to 500°F temperatures. It has a 100 to 70 mix ratio by weight.
The bonds are durable, tough, and resistant to thermal cycling and chemicals, including water, oil, and most organic solvents. It’s service operating temperature range is –60 up to 500°F.
EP35LV is 100% reactive and doesn’t contain any diluents or solvents. Only contact pressure is required during cure.
Master Bond Inc.
154 Hobart St.
Hackensack, NJ 07601
(201) 343-8983
www.masterbond.com
