Flushing Rings Offer Accurate Measurement, Fast Assembly
The Rosemount 319 Flushing Rings from Emerson provide a process-to-seal connection and allow for faster diaphragm seal maintenance.
May 26, 2023
The Rosemount 319 Flushing Ring with valve-integrated design from Emerson offers accurate differential pressure measurement and lower maintenance suitable for a wide range of differential pressure applications. Available in traditional and compact options, the Rosemount 319 Flushing Rings provide a process-to-seal connection and allow for faster diaphragm seal maintenance without disconnecting them from process flanges.
Both versions of the Rosemount 319 Flushing Rings come pre-assembled, including the flushing ring, matching valves and connections, allowing technicians to commission devices faster by eliminating the need to procure and assemble components onsite. Rosemount 319 Flushing Rings are factory leak-tested so users can mount products to vessels right out of the box. When installed, diaphragm seal maintenance is significantly faster without compromising safety while reducing stocked inventory and management of multiple vendor piece-parts.
Emerson
