Advantech
Advantech's EKI-8510G Time-Sensitive Networking (TSN) Ethernet switch
Ethernet Switch is TSN Compatible
May 26, 2023
The EKI-8510G from Advantech supports real-time communication.
Advantech has released the EKI-8510G Time-Sensitive Networking (TSN) Ethernet switch. Advantech is a partner in the CC-Link Partner Association’s (CLPA’s) initiatives, promoting CC-Link IE TSN applications to various industries. EKI-8510G obtained CC-Link IE TSN Class A & B certifications, enabling a wide variety of applications in industrial environments. TSN is the industrial communication technology that realizes the integration of information technology and operation technology, bringing the benefits of time synchronization, high bandwidth and reduced transmission latency.
The EKI-8510G is the next generation of industrial Ethernet switch, which supports real-time communication through TSN technology, providing determinism over Ethernet-based networks to guarantee data delivery for critical time-sensitive applications. Designed with industrial use cases in mind, EKI-8510G supports full layer 2 managed functionality and complies with EN 50121-4 transportation regulations for approval for railway track use. Equipped with 8 gigabit ports and 2 gigabit SFP ports, EKI-8510G offers high-speed transmission and an SFP socket for easy and flexible fiber connectivity.
Advantech
Diaphragm Pumps Critical in Degassing for Chromatography, Inkjet Applications
Effective degassing is essential for maintaining accuracy and performance in chromatography and inkjet systems. Discover how diaphragm pump technology ensures reliable, bubble...
How Changing Inlet Conditions Affect Diaphragm Pump Performance
Inlet conditions can significantly impact the efficiency and reliability of diaphragm pumps. Learn how variations in pressure, temperature, and media composition influence performance...
