AutomationDirect
AutomationDirect Swivellink Standard series device mounting system
Mounting System Offers Flexible Use of Vision, Scanners
May 25, 2023
The Swivellink Standard series offering from AutomationDirect are modular and versatile.
AutomationDirect has added Swivellink Standard series device mounting systems to its Barcode/RFID/Vision product category. Device mounting systems are assembled using several components and can be configured to mount vision cameras, lights, sensors and scanners. They allow for precise adjustment and ease of equipment installation.
These mounting systems are modular, and components are selected individually to suit the needs of the application. The systems are custom-configured and start with a base, which is fastened to the mounting surface. Then a link or tee is connected using knuckles which provide full rotational adjustment. Mounting plates finish the mounting system, predrilled for specific manufacturer equipment or blank for custom drilling.
Components are available in metric or imperial units and include bases, knuckles, links, tees, mounting plates, sensor mounts and optional clamp handles.
AutomationDirect
