Electriflex
Electriflex Liquatite graphic
Food-Grade Conduit Includes Antimicrobial Jacketing
April 4, 2023
Electri-Flex's conduits are suited for food processing, pharmaceutical, bottling equipment and clean room installations.
The UL-listed, flexible, nonmetallic conduit Type LNMP-Food Grade now has an improved antimicrobial jacketing that offers a wider temperature range and is made with a new food processing blue jacketing. Type LNMP is made of flexible PVC with a nylon reinforcing braid and is ideal for continuous flexing applications as it does not contain a metal core that could fatigue with repeated flexing.
Liquatite food-grade electrical conduits now include Type LNMP-Food Grade, LAFG, LSSFG and NMFG, and are suited for food processing, pharmaceutical, bottling equipment and clean room installations. The flexible PVC jacketing now contains an antimicrobial biocide additive. This additive inhibits the growth of commonly known food processing microbes, such as E. coli, listeria and salmonella, and even shows a reduction of these microbes over a 24-hour period.
Electri-Flex
Food Processing sheet
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
