EXAIR
The EXAIR 3/8 NPT HollowStream nozzle
Spray Nozzle System Solves Common Industry Problems
Jan. 26, 2023
The EXAIR 3/8 NPT HollowStream sports a vaneless tangential flow design.
The EXAIR 3/8 NPT HollowStream liquid atomizing spray nozzle provides a hollow cone spray pattern for pressurized liquids. They are applied to solve cooling, cleaning, foam breaking, rinsing and dust suppression applications for industry. The tangential flow design is vaneless, with wide open internal features to resist clogging and works well with liquids containing particulate.
These liquid nozzles produce a uniform distribution of liquid in a ring pattern with medium to large droplets. Their right-angle design is compact and can fit in small areas. Liquid operating pressure is up to 250 PSI. HollowStream nozzles are CE compliant and available in a variety of flow rates. They complement EXAIR’s large line of other 1/8, 1/4, 3/8 and 1/2 NPT liquid nozzles which are also available in a variety of liquid patterns and flow rates.
EXAIR
