AutomationDirect
AutomationDirect float switches
Float Switches Work With Various Liquids
Jan. 26, 2023
AutomationDirect has bolstered its float switch lineup with several new offerings.
AutomationDirect has added ProSense float level switches, including the FLS-VM-800 float switch which has a ¾ in. PVC pipe fitting for use in HVAC condensate lines, and the FLS-VD series that includes a ¾ in. MNPT connection for mounting to most standard ¾ in. bungs in 55-gallon drums.
A selection of top- and side-mount float switches, in medium and large sizes, has also been added with various material constructions for compatibility with a variety of liquid types, temperature ranges and system pressures. The ProSense float level switches are UL recognized, CE marked and RoHS compliant.
AutomationDirect
