BRECOflex has expanded the move-series timing belt product line with the addition of AT8 MOV Open-Ended M for linear drives. Move-series timing belts are FEA optimized, laminate coated polyurethane timing belts with galvanized steel tension members. This re-engineering of the standard timing belt offers up to 75% greater stiffness and tensile strength with 30% more tooth shear strength, on average.
For design engineers to end-users, making the switch from standard polyurethane timing belts to move-series allows for a decrease belt width while maintaining the same strength and safety factor for a more compact, quieter drive. The laminate coating and optimized tooth design also increases performance life.
Move-series timing belts are available in open-ended for linear drives in AT8, AT10 and AT15 with standard widths of 25, 50, 75 and 100 mm. Move-series truly endless BFX for power transmission drives comes in AT8, AT10 and AT15 pitches in standard widths of 16, 25, 32, 50, 75 and 100.
