EXAIR
The TurboBlast Safety Air Gun
Safety Air Gun Provides Power and Control
Nov. 17, 2022
EXAIR’s TurboBlast is well suited for blowoff applications requiring maximum force.
The TurboBlast Safety Air Gun is capable of producing up to 23 lb of force with a simple press of a button trigger. It is a solution for blowoff applications requiring maximum force such as removing stubborn or heavy debris like slag and flash, part drying or cooling from a distance, as well as heavy duty cleanup in busy facilities.
The TurboBlast features a cast aluminum handle with a rugged elastomer grip that’s not only comfortable but UV resistant, chemical resistant, and insulated from heat or cold. The light touch activation trigger creates a powerful blast of air and also includes a “Dead Man’s” grip that turns air off if the air gun is dropped. All models include an integrated nozzle guard for safety. Models are available with an adjustable gate valve to control blowing force on the fly, or without the gate valve.
EXAIR
