The OPEXplus digital torque wrench can measure both the torque and the angle of rotation. It covers a range of torques from 3 to 800 Nm, and it transfers the tightening results to any IT system without the need for additional control. OPEXplus torque tools are recognized in networks via the embedded Wi-Fi module.
When a tool in an assembly line is changed, the module can simply be plugged into the new screwdriver. The supplied software allows parameterization via a hotspot, the customer network or a serial interface. The intelligent OPEXplus transmits the tightening results with a tightening curve, as well as maximum torque and angle of rotation, directly to any of the user’s IT systems without the need for additional control.
Aug. 29, 2024
Aug. 28, 2024
