Courtesy Spectronics Corporation
The Industrial LeakTracker Plus
LeakTracker Flashlight Assists in Leak Detection
Aug. 8, 2022
The Industrial LeakTracker Plus from Spectronics Corporation is well suited for spotting close and long-distance range leaks.
The Industrial LeakTracker Plus is a 365 nm UV LED high-intensity leak detection flashlight. It features an adjustable focus making it a dynamic tool for close and long-distance range leaks and a laser pointer for further visual aid in spotting hydraulic leaks. It has a runtime of nine hours and an li-ion battery charges inside the flashlight.
It works with all Spectroline ULTRA fluorescent dyes to provide technicians with the optimal fluorescent dye response and contrast when scanning for hard-to-find leaks. It even allows for more accessibility when searching near moving parts due to its more compact and long-range design.
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
Aug. 28, 2024
