The M series HY is designed for all applications requiring vacuum-tight connections in harsh environments. Its ultra-low leak rate, coupled with a wide operating temperature range, allows for unmatched performance in optical enclosures or high-altitude applications. This new addition to the M series lineup provides customers with the highest density ratchet coupling connectors on the market where vacuum-tight integrations are required.
The vacuum tight connectors offer solutions for aerospace, automotive, defense, tactical communication and UAV applications. Features include ultra-low leak rates, optimized PCB tails enabling easier PCB routings on high-density configurations, lightweight materials and vacuum-tight sealing over an extended temperature range.
