Grid Connect
Universal translator
Universal Translator can Service Multiple IP Protocols
June 22, 2022
The module adds a full array of industrial protocols to any new or legacy device.
An embedded module has been developed that serves as a universal translator for enabling serial devices (RS-232, 422, 485, SPI, I2C) to communicate via protocols such as EtherNet/IP, Modbus TCP, PROFINET, BACnet/IP and others. OEMs also gain the capability to push data from plant-floor and field devices to analytical and business applications via OPC UA and MQTT.
The module offers device makers a quick-to-market, affordable and simple solution for adding a full array of industrial protocols to any new or legacy device a manufacturer uses. If an OEM’s device is interacting with the factory in, say, Modbus, the module enables the equipment maker’s device to communicate in a next-gen protocol like PROFINET.
Real Time Automation, Inc.
Grid Connect, Inc.
