IDEC Corporation
PS3V Series
Power Suppliers Cover a Wide Input Voltage Range
April 26, 2022
IDEC's PS3V Series adds several new features.
The PS3V Series power supplies adds new features like push-in connections for simplified installation. The PS3V power supply family accepts a wide input voltage range from 85 to 264 VAC, and it provides an output of 5, 12 and 24 VDC with capacities ranging from 15 to 150 W, both depending on the model. Output voltage is user adjustable ±10%, and the 24 VDC versions deliver efficiencies ranging from 83 to 88%.
A metal housing protects the PS3V power supply, and it can be mounted in four orientations, by direct panel mount or DIN rail bracket. Mounting brackets are the same as for the previous PS3X series, providing easy upgrade options. Models are available with traditional screw terminals, or with safe and efficient push-in terminals for rapid one-step wiring. A wide operating temperature range from −25 to +70°C ensures these power supplies work in the most challenging environments.
IDEC Corporation
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
Aug. 28, 2024
