Keystone 6266ed4b09033
Plastic Battery Holders Now Include On/Off Switch
April 26, 2022
Densi-Pak is ideal for self-contained powering components in various applications.
The Densi-Pak covered plastic battery holders now includes a built-in On/Off switch. The switch eliminates the need for additional components in designs using AA and AAA batteries, which is ideal for self-contained powering components in a variety of applications. These high-performance battery holders are made with an ABS Plastic case and nickel-plated coil spring steel contacts for a reliable, low-contact resistance battery connection.
The Densi-Pak, snap-on cover design protects and secures the batteries within the compartment to prevent shorting or damage. These switched battery holders are available to accommodate 2 or 3 AA or AAA batteries. They also are available are IP65 water and dust resistant versions to accommodate 2, 3 or 4 AA cells.
Keystone
