The SHF Series split hydraulic flange plugs are designed for use on SAE 3,000 lb, four-bolt split hydraulic flanges, allowing for maximum flexibility. Designed to protect the port, flange surface and bolt holes from damage and debris during transit, handling and storage, the SHF series Split Hydraulic Flange Plugs are easy to install and remove and are molded in red LDPE plastic to fit 3/4-12 thru 2-1/2-40 nominal flange sizes.
