Red Lion
PM-50 graphical panel meter
Graphical Panel Helps Connect Legacy Equipment
Feb. 16, 2022
The PM-50 makes it easier for machine operators to utilize data from legacy equipment.
Legacy equipment in plants can make it difficult, time-consuming and costly to extract data from the machines to help improve performance. Red Lion’s newly launched graphical panel meter, PM-50, is designed to change that. Available through Allied Electronics & Automation, the new wireless smart panel meter makes it easier for machine operators to unlock and use data from their factory floor. The PM-50 can be used in industrial factories, food and beverage, water/wastewater and packaging plants, and anywhere else panel meters are currently used.
Harvesting plant data is as simple as unplugging the old meter, inserting the PM-50 and connecting it to Wi-Fi. Its graphical interface is intuitive and similar to personal smart devices most operators are comfortable using every day. Built-in Wi-Fi connectivity delivers data from the panel meter to the operator’s smartphone or tablet using an app. The app provides a simple upgrade path for future improvements. Wired connectivity is also available via Ethernet and Modbus.
Red Lion Controls
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
