Continuous Jumper Reduce Vibration Interference
WAGO's new offering provides additional options for circuit designs.
The introduction of 3-way and 5-way continuous jumpers has expanded TOPJOB S uses. As with previous jumper introductions, these versions utilize the exclusive jumper retention spring designed into TOPJOB S terminal blocks to ensure a vibration-proof connection every time.
This offering provides additional options when circuit designs need to use the second row of jumper slots on TOPJOB S terminal blocks for other purposes (for example, testing). Combined with staggered jumpers, they are able to cover a wide variety of end-use applications.
WAGO
