FANUC
FANUC's M-1000iA robot
Heavy-Payload Robot Improves Reach, Output
Feb. 14, 2022
FANUC's new offering can handle very heavy products with a wider range of motion.
The M-1000iA robot is capable of handling very heavy products, including automotive components, construction materials and battery packs for electric vehicles. The M-1000iA’s serial-link construction gives the robot a wider range of motion in every direction. It can extend its arm upright or rotate it backwards, which is not possible for typical heavy-payload robots with a parallel-link mechanism.
With a 1000 kg payload, a 3,253 mm horizontal reach and a 4,297 mm vertical reach the M-1000iA is ready to go to work for manufacturers looking to increase output and maximize their production line’s efficiency.
FANUC
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
