The Compact Low Profile SPMA Series Switch Mode Power Supplies are just 63 mm (2.5 in.) deep. Designed for industrial and building automation, the SPMA Series is a compact, low-profile DIN mount solution with three frame sizes from 17.5 mm (15 W) to 70 mm (100 W).
With integrated diagnostics and protection, these products are ideal for applications that demand performance and reliability while maintaining very high efficiency. SPMA Power Supplies also come with 4kVac isolation voltage for use in electric vehicle charging stations.
March 18, 2025
March 18, 2025
March 18, 2025
