ElectroCraft MPW86
Wheel Provides Efficiency For AGVs
Oct. 25, 2021
The MPW86 is well-suited for battery powered applications designed to transport heavy loads.
The MPW86 (200 mm Wheel), provides a peak torque of up to 35 Nm (310 lb.in) at up to 4.3 meters/second, while carrying up to 227 Kg (500 lb.) per wheel. The result of the integrated design of the MPW is in the overall efficiency and performance of the robotic application.
The MPW86 is ideal for larger size automated guided vehicles, autonomous mobile robots, motorized carts and tuggers, or practically any battery powered application designed to transport heavy loads.  Available with eight different motor and gearing combinations, the MPW86 offers a variety of speed-torque configurations to match a wide range of application requirements.
ElectroCraft
Video link
