Integrated Motor Controllers are available with a wide range of standard features for easy integration. Intended for industrial automation applications, they include state-of-the-art brushless servo motors with 4096 lines encoder and CANOpen network protocols in an intelligent plug-and-play package.
The high-performance 60 mm NR5-LD60 series incorporates motor, encoder and drive with smooth and quiet sinusoidal commutation with Field Oriented Control (Vector Control) into a compact unit. The NEMA 23 NH5-DM series is an economical turnkey solution to speed and torque analog motion control. With the elimination of multiple components, connectors, cabling and labor a significant cost savings is realized.
March 18, 2025
March 18, 2025
March 18, 2025
