Actuonix P8 line
Micro Stepper Actuators Feature Compact Design
July 19, 2021
Actuonix actuators provide durability for tight spaces.
The P8 line of micro stepper actuators features an ultra-compact design that offers capabilities for designing push/pull mechanisms. Featuring a long-life stepper motor, the P8 is designed for projects where mounting space is tight and long life is a priority.
The P8 is available in 10 mm, 25 mm, 75 mm and 100 mm stroke length options to fit a wide variety of applications. Two gearing ratios are also available: 49:1 and 165:1, to match specific force and speed requirements. A maximum-duty cycle of 100% is for applications where the actuator will run consistently.
Actuonix Motion Devices
