Muncie Power A30 Series PTO
Power Take-Off Improves Torque Ratings
July 19, 2021
Muncie Power’s product maximizes gear design.
The A30 Series continuous duty power take-off (PTO) offers improved torque ratings for medium- and heavy-duty applications. The A30 Series is a 10-bolt, constant drive PTO designed to fit Allison 3000 and 4000 Series transmissions. Product improvements include maximized gear design for noise reduction, tapered roller bearings for longer life and a new rotatable pump flange for easier installation.
Additional key features include an increased input shaft diameter to increase life and durability, three assembly arrangements and compatibility with Muncie Power’s EX Drive shaft extension, which allows larger pumps to be mounted directly. The A30 Series is applicable for refuse trucks, cranes, snow plows and cement mixers, as well as some other applications that require continuous duty cycles.
Muncie Power
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
