The TOPJOB S Mini terminal block series offers all functions of WAGO’s TOPJOB S line, but with an smaller footprint. At a size 60% smaller than its standard terminal blocks, the Mini features push-in CAGE CLAMP connection
These blocks are available with open tool slot or the easy-to-identify orange push buttons that can be easily actuated with any standard tool. The TOPJOB S Mini terminal blocks can be mounted in as a miniature rail, snap-in mounting foot for chassis mount or direct mount with fixing flange. They are an effective solution where space is limited or where use of DIN rail is not possible.
