The Smart Function Kit for Handling can be used in a variety of areas, such as production handling, machine assembly and packaging. Pick-and-place tasks can also be performed quickly and cost-effectively, as a Cartesian multi-axis system for packages of different sizes, weights and formats.
The new subsystems for multi-axis applications offer noticeable advantages over conventional solutions. The plug-and-produce approach also speeds up the commissioning process considerably. With just a few clicks and minimal engineering work, users can determine exactly which system is suitable for their needs.
The data from LinSelect can be carried over to the configurator for complete system design. Orders can also be placed directly via the Rexroth e-shop. This complete range of tools not only saves time, but it also reduces potential sources of errors.
