Authored by: Edited by Lindsey Frick Key points: Resources: |
A deep-drawn stamping can be more than a metal trash can. Metal blanks can be deep drawn to form complicated shapes of varying sizes.
Unlike the machining process, stations of the stamping press can incorporate secondary operations such as piercing, notching, coining, embossing, beading, and grooving. And the stamping process uses sheets of raw material instead of blocks of metal which can help reduce upfront costs.
However, the stamping process requires extensive metallurgic and process knowledge. For a 101 on deepdrawn stampings, here is a list of basic terminology and some examples of unexpected deep-drawn shapes.
