Pump/compressor
July 7, 2011
The 319 Series oilless, WOB-L piston dc pump and compressor uses die-cast aluminum components for strength and durability
The 319 Series oilless, WOB-L piston dc pump and compressor uses die-cast aluminum components for strength and durability. Designed for mobile applications including air suspension, air doors, air horns, air brakes and clutches, and fuel systems, the RoHS-compliant device includes EMI suppression and features a corrosion resistant e-coated exterior finish, stainless-steel inlet valve, thermally protected motor, and inlet filter/ exhaust muffler for quiet operation. Also available with 12 and 24-Vdc motor and dryer/solenoid. The 319 Series provides up to 150-psi (10.4-bar) maximum intermittent pressure and 93% local barometer of maximum vacuum.
Thomas Division, a Gardner Denver Co.
1419 Illinois Ave.
Sheboygan, WI 53081
(920) 457-4891
gd-thomas.com; gardnerdenver.com
© 2011 Penton Media, Inc.
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
