The PXM409 Series of precision metric-calibrated micromachined silicon transducers and transmitters have a high industrial-grade accuracy of 0.08% and come with a fivepoint NIST traceable calibration. The device’s broad compensated temperature range and thermal compensation make it suitable for scientific or industrial applications requiring a high-accuracy transducer with very-low thermal drift.
Constructed of welded stainless steel, the PXM409 is available in metric ranges of gauge, compound gauge, absolute, vacuum, and barometric pressure. The units have a standard G ¼ metric fitting and are available with cable, DIN connector, or fourpin M12 electrical terminations.
Omega Engineering Inc.
One Omega Dr.
Stamford, CT 06907
(800) 826-6342
www.omega.com
