Insidepenton Com Images Gas Springs Small
Ace gas springs provide just the right amount of force
Sept. 29, 2011
Ace gas springs provides just the right amount of force
Self-contained and maintenance-free gas springs from Ace Controls Inc., Farmington Hills, Mich., provide a range of forces to provide controlled motion for lids, hoods, doors, panels, and machine guards. They are available in sizes from 15 to 28 mm in diameter with forces from 10 to 2,500 N. They all have steel piston rods and cylinders, and grease chambers for low break-away forces. They work in any orientation, although mounting with the rod down is preferred. An internal valve lets the users adjust the force to an application’s requirement. When operating in hot temperatures, it is important to note that for every increase of 18°F (or 10°C), spring force increases by 3.4%.
© 2011 Penton Media, Inc.
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
