Tapping tides for clean energy
Aug. 11, 2011
A 75-ft-high tidal turbine will include a custom-designed brake to prevent overspeeding and eliminate shock loads that could damage the novel power-generating device
Resources:
Atlantis Resources Corp.
Wichita Clutch, an Altra Industrial Motion company
A 75-ft-high tidal turbine will include a custom-designed brake to prevent overspeeding and eliminate shock loads that could damage the novel power-generating device.
Last August, the Atlantis AK-1000 turbine, the world’s largest single-axis tidal turbine to date, was installed at the European Marine Energy Centre in Scotland for testing. Designed by Atlantis Resources Corp. in the U. K, the turbine contains twin rotors 59 ft (18 m) in diameter that harness ebb and flow tides to generate 1 MW of power. These horizontal-axis turbines sit on the ocean floor, in what is considered to be the harshest environment on the planet.
The turbine’s need for a large-capacity braking system eventually led to the use of a wet, multiplate marine turbine brake from Wichita Clutch in the U. K. The Wichita HBS 42-14 clutch installs on the rotor (low-speed) shaft. The unit’s wet-brake technology uses oil shear to generate the braking torque and does not create dust or debris as would a dry-friction brake. Because brake torque transmits through the shearing of the oil film, friction plates never actually touch until relative velocity approaches zero; consequently there is little wear.
For this environmentally sensitive project, Wichita tested and approved the use of a biodegradable synthetic oil as a safer alternative to traditional hydraulic oils. And because the turbine rotors turn at just 6 to 8 rpm, studies indicate the units present little hazard to marine life.
The rugged HBS 42-14 has a dynamic torque capacity of 1.2 MNm and was custom designed to suit the Atlantis parameters for braking torque, controlled and emergency stops, condition monitoring, nacelle mounting, and shaft sealing. It also incorporates a custom hydraulic power pack which provides proportional braking control under normal circumstances and a fast-approach, soft-braking feature in the event of total power loss.
The brake sits inside a dry nacelle. The main shaft, brake, and generator reside in a sealed tube at normal atmospheric pressure. Although not required on the Atlantis turbine, the Wichita brake is capable of full submersion and could be used in a pressurized environment (typical depth 100 ft).
© 2011 Penton Media, Inc.
Leland Teschler
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
