Configurable Components Streamline Packaging
Oct. 23, 2008
Micron PharmaWorks Inc. of Odessa, Fla., builds machines other firms use to package pharmaceuticals. It also rebuilds existing equipment to extend useful life.
Its machines include thermoformers, inspection equipment, card-sealing machinery, tablet feeders, foil pinhole detectors, and package transfer-and-handling devices.
In conducting its line-integration and custommachinery services, the company ended up buying a lot of specialized and custom components. It needed a way to do so without racking up part costs, set-up fees, and minimum order charges.
Jessica Shapiro
Associate Editor
[email protected]
Resources
Micron PharmaWorks Inc., (727) 232-8200,pharmaworks.com
Misumi USA Inc., (800) 681-7475, misumiusa.com
Misumi blog on engineering calculations, tinyurl.com/3tl3xd
Misumi ebook on configurable components, tinyurl.com/46ls55
To streamline design and cut costs, Micron PharmaWorks turned to Misumi USA Inc., Schaumburg, Ill., when designing its TF1 blister packaging thermoformer. Engineers used Misumi’s online CAD configurator to create shafts, bearings, and supports to their own specifications. They downloaded 3D part models into their CAD package to verify fit and function.
The resulting machine is 3.6-m long by 0.9-m wide and 1.8-m high. It forms blister packs 130 80 25-mm deep from 300-mm base and lidding material rolls.
It contains many configurable Misumi components including shafts, bearings, urethane rollers, pulleys, support sections, standoffs, locating pins, rest pads, levers, and knobs. Micron PharmaWorks estimated that configurable components led to savings for the same performance, reliability, and component quality.
Success on the TF1 machine led Micron PharmaWorks to archive configured components for future machines. Says Engineering Manager Michael Ruth, “We realized this source was suitable for custom and rebuild work, but also for standard machines. We could reuse components to improve machine section design, cost efficiencies, and just-intime delivery schedules.”
Ruth also says engineers cut the time needed to design the machines. They found it easy to configure and download part models into large 3D MCAD assemblies that worked with in-house design, validation, and datamanagement software.
Engineers from Micron PharmaWorks designed the TF1 blisterpack thermoformer using configurable parts from Misumi. The finished machine design called for configurable components for moving parts like bearings, rollers, and pulleys as well as stationary parts like standoffs, rest pads, and knobs.
Micron PharmaWorks employs Misumi’s configurable components on its custom and rebuilt machines like those shown here.
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
