CNC router brochure
Aug. 22, 2001
A brochure, called H846, describes six CNC routers designed for high-speed production in wood, plastic, foam, brass, aluminum, composites, and other materials.
A brochure, called H846, describes six CNC routers designed for high-speed production in wood, plastic, foam, brass, aluminum, composites, and other materials. It includes photos of sample products created with the materials and also cutting heads, such as Colombo spindles with automatic toolchangers, air spindles, an engraving head, a Porter cable router, and a variable-speed milling/drilling head. The systems described in the brochure are shipped fully assembled and include servocontrol system drives, high performance spindles, and vacuum tables. Their work area sizes range from 8 8 in. to 41 49 in. and software options include ArtCam, Visualmill, Mastercam, CASmate, EnRoute, G-code, and many others.
Techno-Isel, 2101 Jericho Turnpike, New Hyde Park, NY 11042, (516) 328-3970.
June 27, 2025
June 25, 2025
June 25, 2025
