Puttin’ on the glitz
Jan. 10, 2008
RPC beauté in France pulled out all the stops when it designed packaging for Color Fever Gloss ? a lip gloss from Lancôme.
To make the vials, collars, and caps, RPC uses coinjection, overmolding, ultrasonic welding, and a recently developed technique of partial electroplating to create a translucentmetallic finish.
The vial, which is injected in copolyester, has a strong geometric shape despite large variations in wall thickness. The surface is hot-stamped with the Lancme logo before it’s overprinted with a clear tampo print to boost scuff resistance.
To get the metallic-looking collar, the neck is coinjection molded from two polymers, and then partially electroplated by a proprietary technique. The insert-molded cap is also plated, and then overmolded with high-clarity Surlyn resin from DuPont, Wilmington, Del. The complete pack is produced on fully automated lines with camera inspection and tests for air tightness.
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
