Machine vision gives security cameras an edge
The system also gives security officers instant replay and other options that simplify monitoring large, complex areas. Previous systems relied on simplistic approaches to detect incidents and were prone to false triggers generated by moving foliage, passing headlights, and cloud shadows. "Our system uses algorithms with temporal processing and model-based analysis to recognize motions common to particular scenarios, such as moving people and vehicles," says Brent Nowak, manager of automation engineering at the Institute's Automation and Data Systems Div. "It also disregards or overcomes false triggers caused by moving foliage and shadows and can detect stationary objects left at the scene, such as packages and suitcases." |
