Simple way to parallel program
Sept. 14, 2006
Supercomputers often conjure up images of government labs with racks of processors and little concern for budgets.
Molecular models for weather and pollution studies grew so large that Massachusetts Institute of Technology Research Chemist Bryan Wong ran out of computing power. The models involved 20,000 20,000 matrices and would not run on a desktop PC. His solution was to continue work in Matlab on a PC with Star-P for parallel coding. Simulations only took a few minutes on a 16-processor SGI Altix high-performance server.
Actually, highperformance servers and clusters of multiple processors are in wide use today. But it's difficult to program parallel systems.
Boston-based Interactive Supercomputing Inc. says its Star-P software overcomes this difficulty. "Users code algorithms and models on desktop computers using familiar mathematical software such as Matlab from MathWorks," says Interactive's Vice President Ilya Mirman. "Star-P parallelizes code on the fly, letting users scale applications across multiprocessor systems in real time."
So far, Star-P works on parallel servers such as SGI Altix and AMD Opteron-based clusters. Matlab was the initial application for Star-P, and interfaces to other desktop math programs are in the works. "Engineers will be able to load programs written in C or Fortran onto the server, call them through the Star-P client, and get supercomputer performance," he says.
Of course, parallel execution on multiprocessor computers is not new. "But writing software to run on parallel systems has been a challenge. Rewriting applications in languages such as C, Fortran, or MPI is time consuming a matter of years in some cases. What's more, algorithms and digital models are becoming more complex, dramatically outpacing the steady improvement in desktop computers' processing power," says Mirman.
Star-P reverses the trend, he adds, because it lets users work in familiar desktop software. "Users can write just enough of an application to start testing with real data. They can pause executions, change parameters, and restart them. These interactive workflows cut months off projects," he adds.
MAKE CONTACT
Interactive Computing Inc,
interactivesupercomputing.com
MathWorks Inc.,
matlab.com
Discover how pump motor parameterization provides unprecedented control capabilities, allowing KNF to tailor pumps to your exact needs for increased productivity, extended pump...
July 28, 2025
Ensure accuracy and reliability in your lab. Discover how KNF's advanced food testing equipment provides the precision you need for critical analysis and results.
July 28, 2025
Explore the vital role of KNF pumps in cutting-edge fuel cell technology. Learn how our innovative solutions contribute to efficient and reliable energy systems.
July 28, 2025
Unlock optimal pump efficiency by understanding suction height. This essential guide explains how to prevent common issues and ensure peak performance for your applications.
