Infrared spectrometer tests bowling pins
Sept. 13, 2007
The United States Bowling Congress seems intent on removing excuses for throwing another gutter ball.
The organization has begun measuring and identifying the chemical structure of sample bowling-pin materials with a Fourier Transform Infrared Spectrometer, an optical instrument with a computer interface.
The three tested materials — the outer clear coat, pin coating, and base material — must maintain at least a 98% correlation to the original samples for the pin to be acceptable for USBC competition. In addition to bowling pins, the infrared technology could assist the USBC in testing bowling-ball cover stocks, lane surfaces, oils, and cleaners.
The Fourier Transform Infrared Spectrometer tests tiny samples of bowling-pin materials.
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
