NASA Tests Rocket engine Components
Oct. 23, 2008
Technicians at NASA’s Marshall Space Flight Center in Huntsville, Ala., recently completed a series of tests on a gas generator, a key component in the J-2X rocket engine.
The J-2X engine will power the second stage of the Ares 1 rocket which will ferry astronauts to the Space Station as well as the Moon.
The gas generator was built by Pratt & Whitney Rocketdyne and will drive the Ares I’s turbopumps. Prior to main engine ignition, the generator will burn some Ares I rocket fuel (liquid hydrogen and oxygen) to create a stream of hot gases. These gases will power turbomachinery which then pumps rocket fuel into the main combustion chamber. The goal is to make the Ares 1 engine and gas generator reusable.
If all goes well, the Ares 1 will start carrying the Orion crew capsule and as many as six astronauts and small payloads to the space station in 2015.
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
