Julie Kalista
Online Editor
| Solar-powered airplane shown over a computer-generated radar image of the surface of Venus. (Artist's conception by Terence K. Condrich of InDyne, Inc.) |
"The vehicle would be unmanned, solar-powered, and made of strong, light-weight materials," says Colozza. The plane's body would be made of plastic-like material called ionic polymer-metal composite that deforms when exposed to electric fields. The plane would also use thin sheets of photovoltaic material and a lithium battery.
The plane would fly like an albatross, gliding great distances and circling over the same area for long periods of time, flapping only to regain altitude. To maneuver, the aircraft will adjust its wings into complex shapes, rather than using ailerons or a rudder.
Colozza believes this plane could be flying in just a decade or two, with countless uses such as gathering scientific data, relaying communications, and surveying terrain. He also believes the plane could be used on other planets with atmospheres that would ground air-breathing planes.
More Information:NASA Glenn Research Center
This web-only article appears in the Tech Insider e-newsletter. If you enjoyed this article and would like to read more like it, sign up today for our free e-mail newsletters!
Related
