Drives take on many motors
May 6, 2004
Volts/Hertz ac drives feature isolated front ends and come in NEMA-4X aluminum enclosures.
The VFDA4X04-D230-PCM and VFDF4X04-D230-PCM have a minimum speed-adjustment potentiometer, dc injection braking, and automatic and manual restarts. Units can accept a speed reference signal without a separate isolation card and work with three-phase induction, single-phase permanent split-capacitor, shaded-pole, and synchronous motors. Available to 1.5 hp, enclosures can be either gray or USDA-rated white epoxy for food environments.
Minarik Drives, 14300 De La Tour Dr., South Beloit, IL 61080, (800) 646-2745, www.minarikdrives.com
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
